kaitova
Hello rgarcia60 ,
I have answer for you, the most probably you have correct results of your simulation. but you have settings in the analysis results representation, that are averaged in s special way, thus, they give results more than they should actually. I had this issue with Abaqus long time ago, change of setting helped. You can try to find out yourself which setting can be adapted. I will look as well and send a link if I find.
Regards, Kamilla
