Keyur Kanade
It will be bottom up approach. So it would mesh faces first and then volume. So it depends on how many faces/edges you have in your model and defeaturing size you are using. Please start with a larger element size and try to mesh. Then you will get some idea on what should be min size. Without looking at the model, it is difficult to predict the size. Please do some iterations.
Keyur
