The cell sizing will be based on the jet fan diameter etc: then you need to keep a sensible aspect ratio.  Very roughly you need 5-6 cells across a gap, and keep the aspect ratio below about 3-4 where the flow is changing. Inflation and regions with no change in flow along the cell can be much higher.
