Jeroen
The code supplied also does not work and gives the following error:
Error: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).nnThe system cannot find the file specified.
nnC:Userss151272DocumentsMasterAfstudeer_opdrachtANSYSlibudfwin643d_hostlibudf.dll
Error Object: #f
I currently have Windows Visual 2019 and Pelles C installed as compilers. However, I have never established a coupling between Fluent and one of these compilers. How should this be done?
