Karthik R
Administrator
System Coupling requires 3D meshes and cannot exist with 2D mesh. Please refer to the following section of the Users guide to understand this better.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/flu_ug/flu_wb_sec_wb_syscoup_capabilities.html
If you are unable to open the User's guide, please take a look at the following link.
https://studentcommunity.ansys.com/thread/how-to-access-the-ansys-online-help/
If you are looking to transfer heat from between two solids or a solid and a fluid, please ensure shared topology is applied properly. This should create a wall and wall-shadow. You should be able to use the 'Coupled wall' in Fluent to model these scenarios. Please refer to the Fluent User Guide for more details.
I hope this helps answer your question.
Thank you.
Best Regards,
Karthik
