Karthik R
Administrator
In order to get your proper cell zone names, please create a Named Selection for your 'Volume' and not just for the boundaries. For example, if all the volumes in your geometry are part of the same single fluid, please go ahead and provide a named selection to this volume - let's call it 'Fluid'. Instead of seeing different parts under cell-zone in Fluent, you will see the name 'fluid' here.
Please note that material properties are added at the cell zone level. So, if you have multiple solids in your computational domain, please create separate named selections for them. This will allow you to add material properties later in Fluent appropriately.
Thank you.
Best Regards,
Karthik
