Wenlong
Hi glouvincs01,
It is not surprising if you have your first frequency very high because, as you mentioned, all the contact becomes linear bonded contact and all the bodies act as a whole. Imagine you do a modal analysis on the blue body only.
For shock wave propagation problems, I would use an Explicit solver. You can use either Ansys Explicit or Ansys LS-DYNA.
Wenlong
