Mike Rife
@manvendrayadav  Wear and element erosion are normally quite different in terms of amount of material removal.  If you want to actually wear, then you may want to investigate either a time transient solution with the Mechanical APDL solver (Mechanical is the pre/post processor).  Wear can be added to a contact pair.  Or if the model is best solved with an explicit code then Workbench LS-Dyna can also include wear.
