Jeroen
Your code gives me the exact same error:
** WARNING: Automatically switched to run in parallel -t1 mode. **
** Detected non-parallelized UDF usage, enabling parallel usage. **
** If you encounter any issues, please re-run with -t0 flag. **
****************************************************************************udf_names.c and user_nt.udf files in 3d_node are upto date.
(system "copy "C:PROGRA~1ANSYSI~1v195fluent"fluent19.5.0srcudfmakefile_nt.udf "libudfwin643d_nodemakefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win643d_node")# Generating ud_io1.h
Hello.c
# Generating udf_names.c because of makefile Hellbj
udf_names.c
udf_names.c(7): error C2059: syntax error: '}'
udf_names.c(8): warning C4034: sizeof returns 0
Done.
