When the model is complete, the mass summary should show 255 kg.  You will want to know the mass of each major component such as the battery. The weight of the battery will be distributed to the points where it connects to the frame.
How does the force from the wheel get to the frame? Is there a spring?
Each tube is individually midsurfaced. Thicker tubes will have a larger sheet thickness value assigned than thin-walled tubes.
