jatin prasath
I am attaching a hand drawn diagram. The object here is is made up of 2 different material so has a bouyant force acting in the less dense material. The other material has same density as fluid. Because of this there will be a torque due to which the body will rotate and there will be an increase in pressure dir to it's motion under the fluid.
