arman1armament
I only have install file, i coppied the content of it below. No install.err files and there seems to be no errors there. I have tried reinstalling it several times by now, and i was deleting the folder each time after uninstalling. Is there any way of just downloading the file separately and just copying it in?
Start Installation: Sat Mar 7 00:285 2020
Revision: 2020 R1
Platform specifics:
    Windows
Username of Installer: DESKTOP-6U7PVT9Arman
User Has Administrator Privileges
C:UsersArmanAppDataLocalTempans_install_tmp8084instcore.exe -usetempdir C:UsersArmanAppDataLocalTempans_install_tmp8084 -launchdir C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64 -admin
Initial mount directory:
Installation Directory:
    C:Program FilesANSYS IncANSYS Student
Windows x64
Date verification complete...No conflicts found.
The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
This may take a while ...
Successfully copied prerequisites from media.
You don't need to install any prerequisites.
Reading the installation media contents - please wait.
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64framewrkWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64instcoretclCOMMON.TGZ ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64instcoretclWINX64.TGZ ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64commonWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64commoninstallWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configscommonWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64cpythextWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64cpythnewWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64turbogrdWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configstgWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64cfxcomonWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64instutilINSTUTIL.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64instcoretkCOMMON.TGZ ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64instcoretkWINX64.TGZ ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configsclientlicensingWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configswbWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64sgchartsWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64fwgfxWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addinsWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addincfgwbWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64corewbWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64cadscadaisolWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64cadscadregistryWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64ekmWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addincfgekmWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addincfgminervaWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64meshingWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64blademodelerWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64apipsrvWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64designmodelerWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64syscplgWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64rsmWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addincfgturbosysWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64secWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64ccmWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64cadsacisparaWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64ansysWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addprintgeometryWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configsansysWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addincfgansysWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64solverWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64aasWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64dataDATA.GZ ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64apdlAPDL.GZ ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64geomparaWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addincfgmechWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64autodynWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addincfgautodynWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64cfxWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64polyflowWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configspolyflowWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addincfgpolyflowWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64aqwaWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addincfgaqwaWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configsaqwaWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addincfgcfxWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configscfxWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64postWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64cffWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64fluentcWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64fluentsWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64fluentaWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64fluentuWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64fluentpWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64fluentmWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64fluent2dWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64fluent2ddpWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64fluent3dWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64fluent3ddpWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addincfgfluentWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configsfluentWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64distcompWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addincfgcfdpostWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64aviewWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configsaviewWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64spaceclmWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configsspaceclmWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64icemwbWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64electroWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64ecadxltrWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64cadsspatialiopWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64acpWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addinsacpWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configsacpWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64hlphlpviewerHLPVIEWER.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configshelpWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64tpWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64tphdf5WINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64tpzlibWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64tpopenjreWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64chemkinWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configschemkinWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64forteWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addincfgforteWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configsforteWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64fensapWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configsfensapWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64configsansconfigdllWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addincfggrantaWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64addinsgrantaWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64studentWINX64.7z ...
  Extraction: C:UsersArmanDownloadsAnsysACADEMICSTUDENT_2020R1_WINX64licenseWINX64.7z ...
RSS is disabled
Performing licensing configuration via the following command...
   "C:Program FilesANSYS IncANSYS StudentShared Filesbinwinx64tclsh.exe" "C:Program FilesANSYS IncANSYS StudentShared FilesLicensinglicadminscriptsLicAdminMain.itcl"  -silentinstallclient -release "2020 R1" -lang en-us
Licensing configuration has completed.
Running C:Program FilesANSYS IncANSYS Studentv201commonfilesconfigswinx64configAnsConfigCommon.exe
Configuring ANSYS TurboGrid ...
Running C:Program FilesANSYS IncANSYS Studentv201commonfilesconfigswinx64configAnsConfigTG.exe
Creating Start menu items for ANSYS client licensing ...
Running C:Program FilesANSYS IncANSYS Studentv201commonfilesconfigswinx64configAnsConfigWB.exe
Running C:Program FilesANSYS IncANSYS Studentv201FrameworkbinWin64Ans.DriverSetup.exe
Running "C:Program FilesANSYS IncANSYS Studentv201RSMbinAnsConfigRSM.exe" -encodingUTF8
Configuring RSM...
Configuring default RSM and ARC Port numbers for 2020 R1 ...
Done!
User has Administrator privileges
Creating Start Menu Shortcut for RSM 2020 R1 Configuration...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2020 R1Remote Solve ManagerRSM Configuration 2020 R1.lnk
Creating Start Menu Shortcut for RSM 2020 R1 Job Monitor...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2020 R1Remote Solve ManagerRSM Job Monitoring 2020 R1.lnk
Creating Start Menu Shortcut for RSM 2020 R1 Cluster Monitor...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2020 R1Remote Solve ManagerRSM Cluster Monitoring 2020 R1.lnk
Creating Start Menu Shortcut for ARC 2020 R1 Configuration...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2020 R1Remote Solve ManagerARC Configuration 2020 R1.lnk
Running C:Program FilesANSYS IncANSYS Studentv201commonfilesconfigswinx64configAnsConfigANSYS.exe
Adding write permissions for Users and Administrators group ...
Running C:Program FilesANSYS IncANSYS Studentv201commonfilesconfigswinx64configAnsConfigCFX.exe
Running C:Program FilesANSYS IncANSYS Studentv201commonfilesconfigswinx64configAnsConfigAQWA.exe
Configuring ANSYS Viewer ...
Running C:Program FilesANSYS IncANSYS Studentv201commonfilesconfigswinx64configAnsConfigSpaceClaim.exe
Configuring ACP ...
Running C:Program FilesANSYS IncANSYS Studentv201commonfilesconfigswinx64configAnsConfigACP.exe
Configuring Help ...
Running C:Program FilesANSYS IncANSYS Studentv201commonfilesconfigswinx64configAnsConfigHelp.exe
ANSYS Internet Doc has been configured.
Running C:Program FilesANSYS IncANSYS Studentv201commonfilesconfigswinx64configAnsConfigCHEMKIN.exe
Running C:Program FilesANSYS IncANSYS Studentv201commonfilesconfigswinx64configAnsConfigFORTE.exe
Running C:Program FilesANSYS IncANSYS Studentv201commonfilesconfigswinx64configAnsConfigFENSAP.exe
Running "C:Program FilesANSYS IncANSYS Studentv201aisol..commonfilesCADbinwinx64Ans.CadInt.CADConfigurationUtility.exe"
Log files is C:Program FilesANSYS IncANSYS Studentv201CADConfigLogsLatestCADConfigurationMgr.log
MessageLogger.logFilePath is C:Program FilesANSYS IncANSYS Studentv201CADConfigLogsLatestCADConfigurationMgr.log
ErrorLogger.errorFilePath is C:Program FilesANSYS IncANSYS Studentv201CADConfigLogsCADConfigurationMgr.err
Prerequisites ..... Configure Success
SCDM  Workbench  PlugIn ..... Configure Success
Successfully created file associations.
Installation Complete: Sat Mar 7 006:18 2020
