The jumps in cell size aren't going to help, and resolution isn't enough assuming you have fluid regions. What are you trying to model, as I'd expect some temperature variation over a fluid zone.  Also, if you used "hex dominant" method, don't it's only for Mechanical and should never be used for CFD.
