Kalyan Goparaju
Any reason why you have target mass flow rate turned on? This option is used to change back pressure at the pressure outlet boundary in order to establish a flow with a specific mass flow rate. Since you already have a defined mass flow rate (because of the mass flow inlet), I don't see why you need to have this option turned on.
Thanks,
Kalyan
