JamieMyersMechStudent
To start with I'm looking to model the dampening effects (viscosity) of the fluid on the device. Then the magnetic field when the iron particle is added to the fluid which will increase the shear stress of the fluid and increase the dampening effect on the rotating dampener (the second pic shows different configurations of dampeners the fluid will be acting on). I can send through a paper that would help you understand better if you like?
