DianaLeandro
I've already modified the parameter you told me and if the maximum deformation was reduced.
 As for the mechanical properties of the wood already implemented previously, but the deformation is still very high, the maximum deformation of about 5 mm is expected.
Would you know that another aspect can be modified to reduce deformation
How can I plot UTS results?
