Keyur Kanade
if you are getting converged solution in 19.3 then you also should get it in 2020R1.
please cross check all your input conditions.
what is your application? what settings are you using? are able reproduce similar difference on any simple case like flow through pipe?
Please post the questions in appropriate category. Moving this question to other category to get better response.
Keyur
