Keyur Kanade
As ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
please check your temp folder. fluent first writes .cas file and then use temp folder to zip it.
make sure that you do not have any special character in the file name.
make sure you have write permissions for folder.
Keyur
