SaiD
You can try the following: Once your system is solved, right click on Solution Information --> Insert --> Contact. Under the Details, choose Type --> Contacting Area and under Contact Region choose the appropriate contact pair. Then right click and click on Evaluate all Trackers. This should give you the contact area for that particular contact pair.
Hope this helps,
Sai
