Wenlong
The issue is with the Windows Registry key that defines 'AppData' environment variable. You can see from this error message
unable to get value "AppData" from key "HKEY_CU/software/MS/Windows/CV/Explorer/Shell Folders" The System cannot find file specified.
So you will need to figure out why your system does not have AppData set in the Windows registry. (You may need to consult your IT to solve that)
Wenlong
