tsiriaks
that part to setup starting time and ending time from the tips from simutech is just in the case that you don't want any job to start solving when you are at work (this one assumes you finish work at 6pm) , so the 1 st job submitted to ARC will start at 6pm as opposed to start right away if there is no other job running. You can skip this starting/ending time setup step.
