kaitova
Hi Wenlong, thanks
I have managed to run the model, for me it is now important to identify results (which output should I request from ansys) and compare it with the tutorial. So far. I could not see that results are the same. Here are some print screens for the probe of node 7, they are not equal  to the tutorial. The analysis set up pictures are attached as well. Is displacement equal to deformation - I am trying to understand if it is.
Thank you
