vinayak chauhan
Assuming you have a uniform cross-section and isothermal conditions u can calculate the outlet pressure by applying bernouliis equation for compressible flow analytically and attain pressure at outlet , which you can use further in your k-epsilon model. This can be used if you have a simple model.
I hope it works.
thanks,
vinayak
