You have too many nodes and elements for the size of the RAM installed in your computer. Reduce the number of nodes and elements by at least 50%. If you get the insufficient memory error again, reduce the nodes and elements by another 50% and restart your computer before you Solve.
What units did you use when you did the solve?  If it was m, try changing to mm before you Solve.
