setyawandani10
here is the error message
 *** ERROR ***                           CP =    6560.922   TIME= 07:48:06
 Element 35137 (type = 20, SOLID186) (and maybe other elements) has
 become highly distorted.  Excessive distortion of elements is usually
 a symptom indicating the need for corrective action elsewhere.  Try
 incrementing the load more slowly (increase the number of substeps or
 decrease the time step size).  You may need to improve your mesh to
 obtain elements with better aspect ratios.  Also consider the behavior
 of materials, contact pairs, and/or constraint equations.  Please rule
 out other root causes of this failure before attempting rezoning or
 nonlinear adaptive solutions.  If this message appears in the first
 iteration of first substep, be sure to perform element shape checking.
It always happens on that element. and cause error in the end
Best regards,
Dani
