Attached you can see the velocity magnitude for both the porous media and porous jump, using a pressure outlet. The magnitude and distribution pattern for porous media is at least within the expected range, while the porous jump gives very high velocities. Do you understand why this happens? Have I calculated the input parameters wrong?
