We just change the operating pressure and/or material properties if we can assume they're constant. You can't assume constant properties as gas is generally compressible over about 0.3M
I'd not worry too much about the solver for now. Review some of the videos on line and in the Fluent documentation. Then compare your mesh with those before returning to Meshing to fix yours.
