kaitova
Thank you Wenlong,
i finally had time to make it.
all your advises were useful.
I have 2 questions:
1. in the input file there is a "define curve" several times, and only the last one shows the 7 MPa value, I was going to ask why it is several times but now I understand that it must be a curve for the pressure defined as a load and it is several times because it is shown step wise.
2. another question was about final result value,lower than it should be, but after double checking the units, i can see that that was a reason.
I actually have a question, what is control termination? and why value there is in ms?
Thank you for help.
