March 30, 2020 at 3:55 pm
Thank you! I've used those videos as references as well but for some reason it still doesn't work. Previously I was using a more complex geometry imported from solidworks but the model on the image above is as simple as possible made as an assembly in SpaceClaim. The wings appear to be as free faces only after I import the size field. I try to fix it with the quality and connectivity option but it does not work.
