Wenlong
*Control_termination defines how long the simulation runs, and since the unit system I use is mm, g, N, MPa, so the corresponding time unit is ms. Please refer to the consistent unit system website I sent in the previous post.
If you want to learn more about Ansys LS-DYNA keywords cards, you can search LS-DYNA keyword manual, where volume 1 is about setting up the model, and volume 2 is about material modeling.
Wenlong
