Wenlong
I may not make myself clear so let's expand more. For static structural analysis, you can import a CSV file as "External Data" to import initial stress. And that External Data will appear as an "imported load" where you can select the imported load type as "initial stress". But that's not the case for Explicit Dynamics as the only imported load type available is "pressure".
Wenlong
