osmo
Hi peter,
I have created inlet/outlet only by selecting the faces together. In fluent, I add some parameters (model : epsilon k ; cell zones conditions for solid and tri : water-liquid, boundary conditions : 0.7m.s for inlet solid and tri, 0 gauge pascal for outlet pressure, standard initialisation, 1000 iterations)
I know is not the good place to ask this question, but you know my part and step by step that I have done so :
In results, I created vectors for velocity but nothing happens. The same for contour. It's weird. Have you already seen this problem ?
Kind regards, Alex
