Wenlong
As Petersnowman suggested, checking the contact status is a good idea when you have an "unable to detect contact problem". Based on the image you shared, your two surfaces are not initially in contact. I would try reducing the "initial step" size and maybe also the minimum step size in the analysis settings, so that the movement within the first substep is not larger than the pinball region.
Wenlong
