SaiD
Since the two surfaces are rigid, they can be controlled only using Remote Points. To fix the lower surface, insert Remote Displacement, select the lower surface and set all displacement components to 0. Use Remote Force boundary condition for the top rigid surface.
Hope this helps,
Sai
