In Ansys Workbench, if you go to Engineering Data and click on Engineering Data Sources, then under General Materials, you should be able to add the Concrete material.
In addition, there are several tutorials available to get started. Could you share an image of the geometry or a diagram indicating what you want to simulate?
Hope this helps,
Sai
