nevertrust
Thank you sai for your reply,
I assigned Multilinear Isotropic Hardening Properties on Concrete material. I plot Stress vs Plastic strain data but not assigned properly (Highlighted as not assign properly image can find below). How can we put data in Tabular?
Process:
Static Structural
Engineering Data = General materials = concrete
·       Multilinear Isotropic Hardening
·       Fill tabular (import delimited data)
Other properties are default.
Above figure is not clear so here is strain stress data.
Strain Stress (MPa)
0.000000          0.000
0.000761          15.000
0.001100          20.198
0.001622          30.001
0.002200       40.304
0.003300         50.008
0.004600          40.236
0.006703         20.236
0.012000          5.258
I want to simulate the compression test on a cylinder. Dimension of Cylinder is 100 diameter and 200 mm height.
Waiting for your positive response.
Thank you.
