santrondela
without wire--Static Structural (A5)
SET PARAMETER DIMENSIONS ON _WB_PROJECTSCRATCH_DIR
TYPE=STRI DIMENSIONS= 248 1 1
PARAMETER _WB_PROJECTSCRATCH_DIR(1) = G:thesis solidansys26.3.20203.57_ProjectScratchScr20AA
SET PARAMETER DIMENSIONS ON _WB_SOLVERFILES_DIR
PARAMETER _WB_SOLVERFILES_DIR(1) = G:thesis solidansys26.3.20203.57without wire_filesdp0SYSMECH
SET PARAMETER DIMENSIONS ON _WB_USERFILES_DIR
PARAMETER _WB_USERFILES_DIR(1) = G:thesis solidansys26.3.20203.57without wire_filesuser_files
--- Data in consistent NMM units. See Solving Units in the help system for more
MPA UNITS SPECIFIED FOR INTERNAL
LENGTH = MILLIMETERS (mm)
MASS = TONNE (Mg)
TIME = SECONDS (sec)
TEMPERATURE = CELSIUS (C)
TOFFSET = 273.0
FORCE = NEWTON (N)
HEAT = MILLIJOULES (mJ)
INPUT UNITS ARE ALSO SET TO MPA
*** ANSYS - ENGINEERING ANALYSIS SYSTEM RELEASE Release 16.0 16.0 ***
ANSYS Multiphysics
00000000 VERSION=WINDOWS x64 11:51:09 MAR 31, 2020 CP= 1.609
***** ANSYS ANALYSIS DEFINITION (PREP7) *****
*********** Nodes for the whole assembly ***********
*********** Elements for Body 1 "Solid" ***********
*********** Elements for Body 2 "Solid" ***********
*********** Elements for Body 3 "Solid" ***********
*********** Elements for Body 4 "Solid" ***********
*********** Elements for Body 5 "Solid" ***********
*********** Elements for Body 6 "Solid" ***********
*********** Elements for Body 7 "Solid" ***********
*********** Elements for Body 8 "Solid" ***********
*********** Elements for Body 9 "Solid" ***********
*********** Elements for Body 10 "Solid" ***********
*********** Elements for Body 11 "Solid" ***********
*********** Elements for Body 12 "Solid" ***********
*********** Elements for Body 13 "Solid" ***********
*********** Elements for Body 14 "Solid" ***********
*********** Elements for Body 15 "Solid" ***********
*********** Elements for Body 16 "Solid" ***********
*********** Elements for Body 17 "Solid" ***********
*********** Elements for Body 18 "Solid" ***********
*********** Elements for Body 19 "Solid" ***********
*********** Elements for Body 20 "Solid" ***********
*********** Elements for Body 21 "Solid" ***********
*********** Send User Defined Coordinate System(s) ***********
*********** Set Reference Temperature ***********
*********** Send Materials ***********
*********** Create Contact "Bonded - Multiple To Solid" ***********
Real Constant Set For Above Contact Is 23 & 22
*********** Fixed Supports ***********
******* Constant Zero Displacement X *******
******* Constant Zero Displacement Z *******
*********** Define Pressure Using Surface Effect Elements ***********
LIST DATA TABLE DMGE FOR MATERIAL 20
ANSYS Multiphysics
00000000 VERSION=WINDOWS x64 11:518 MAR 31, 2020 CP= 35.906
DMG EVLU (DMGE) Table For Material 20
Material Prop Degradation
1
Temps 0.0000000e+000
FIBR TEN 7.5100000e-001
FIBR CMP 5.0000000e-001
MATX TEN 8.0000000e-001
MATX CMP 5.0000000e-001
0.0000000e+000
0.0000000e+000
***** ROUTINE COMPLETED ***** CP = 35.969
--- Number of total nodes = 1485655
--- Number of contact elements = 1030253
--- Number of spring elements = 0
--- Number of bearing elements = 0
--- Number of solid elements = 682036
--- Number of total elements = 1712289
*GET _WALLBSOL FROM ACTI ITEM=TIME WALL VALUE= 11.8605556
************************* SOLUTION ********************************
***** ANSYS SOLUTION ROUTINE *****
