santrondela
FOR ALL APPLICABLE ENTITIES
WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE STRS ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE EPEL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE EPPL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE AESO ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
NONLINEAR STABILIZATION CONTROL:
KEY=OFF
KEY TO TERMINATE RUN IF NO CONVERGENCE= 1
DEGREE OF FREEDOM (DISPLACEMENT) LIMIT= 0.78886E-30
CUMULATIVE ITERATION LIMIT= 0
ELAPSED TIME LIMIT (SEC)= 0.0000 ( 0 HOURS 0 MIN)
CPU TIME LIMIT (SEC)= 0.0000 ( 0 HOURS 0 MIN)
*GET ANSINTER_ FROM ACTI ITEM=INT VALUE= 0.00000000
*IF ANSINTER_ ( = 0.00000 ) NE
0 ( = 0.00000 ) THEN
*ENDIF
***** ANSYS SOLVE COMMAND *****
*** WARNING *** CP = 42.953 TIME= 11:51:45
Element shape checking is currently inactive. Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.
*** NOTE *** CP = 57.188 TIME= 11:51:55
The model data was checked and warning messages were found.
Please review output or errors file ( G:thesis
solidansys26.3.20203.57_ProjectScratchScr20AAfile.err ) for
these warning messages.
*** SELECTION OF ELEMENT TECHNOLOGIES FOR APPLICABLE ELEMENTS ***
--- GIVE SUGGESTIONS AND RESET THE KEY OPTIONS ---
ELEMENT TYPE 1 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
HYPERELASTIC MATERIALS. NO SUGGESTION IS AVAILABLE AND NO RESETTING IS NEEDED.
ELEMENT TYPE 2 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
KEYOPT(1-12)= 0 0 0 0 0 0 0 0 0 0 0 0
ELEMENT TYPE 3 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
ELEMENT TYPE 4 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 5 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 6 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 7 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 8 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 9 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 10 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 11 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 12 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 13 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 14 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 15 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 16 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 17 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 18 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 19 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 20 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
ELEMENT TYPE 21 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
