11 0.835362E-02
12 0.121986E-03
13 0.121216E-03
14 0.121862E-03
15 0.121892E-03
16 0.121814E-03
17 0.121239E-03
18 0.121878E-03
19 0.121988E-03
20 0.122401E-03
21 6.31341
Range of element maximum matrix coefficients in global coordinates
Maximum = 526768871 at element 562821.
Minimum = 117109.031 at element 1704882.
*** ELEMENT MATRIX FORMULATION TIMES
TYPE NUMBER ENAME TOTAL CP AVE CP
1 342575 SOLID187 152.000 0.000444
2 1540 SOLID186 2.297 0.001491
3 1540 SOLID186 2.031 0.001319
4 199080 SOLID187 93.984 0.000472
5 42619 SOLID187 21.281 0.000499
6 1737 SOLID187 0.672 0.000387
7 1834 SOLID187 0.984 0.000537
8 1700 SOLID187 1.000 0.000588
9 1760 SOLID187 0.719 0.000408
10 1724 SOLID187 0.641 0.000372
11 1721 SOLID187 0.797 0.000463
12 8539 SOLID187 3.266 0.000382
13 6827 SOLID187 2.875 0.000421
14 8175 SOLID187 3.406 0.000417
15 8196 SOLID187 3.250 0.000397
16 8256 SOLID187 3.344 0.000405
17 6793 SOLID187 2.297 0.000338
18 8203 SOLID187 3.234 0.000394
19 8224 SOLID187 5.094 0.000619
20 9386 SOLID187 4.125 0.000439
21 11607 SOLID187 5.609 0.000483
22 514068 CONTA174 91.656 0.000178
23 514068 TARGE170 43.453 0.000085
24 2117 SURF154 0.531 0.000251
Time at end of element matrix formulation CP = 1021.03125.
ALL CURRENT ANSYS DATA WRITTEN TO FILE NAME= file.rdb
FOR POSSIBLE RESUME FROM THIS POINT
FORCE CONVERGENCE VALUE = 0.8532E+06 CRITERION= 4353.
curEqn= 420828 totEqn= 420828 Job CP sec= 1460.685
Factor Done= 100% Factor Wall sec= 0.000 rate= 0.0 Mflops
*** ERROR *** CP = 1070.719 TIME= 12:17:07
Preconditioned conjugate gradient solver error level 1. Possibly, the
model is unconstrained or additional iterations may be needed. Try
running setting the multiplier MULT on the EQSLV command to greater
than 1.0 (but less than 3.0).
PRECONDITIONED SOLVER CP TIME = 251.812
PRECONDITIONED SOLVER ELAPSED TIME = 251.812
*** NOTE *** CP = 1071.172 TIME= 12:17:09
During this loadstep the PCG iterative solver took more than 1000
iterations to solve the system of equations. In the future it may be
more efficient to choose a direct solver, such as the SPARSE solver,
for this analysis.
NUMBER OF WARNING MESSAGES ENCOUNTERED= 2
NUMBER OF ERROR MESSAGES ENCOUNTERED= 1
***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
*** WARNING *** CP = 1072.000 TIME= 12:17:21
During this session the elapsed time exceeds the CPU time by 70%.
Often this indicates either a lack of physical memory (RAM) required
to efficiently handle this simulation or it indicates a particularly
slow hard drive configuration. This simulation can be expected to run
faster on identical hardware if additional RAM or a faster hard drive
configuration is made available. For more details, please see the
ANSYS Performance Guide which is part of the ANSYS Help system.
A N S Y S S T A T I S T I C S
Release: Release 16.0 Build: 16.0 Update: UP20141203 Platform: WINDOWS x64
Date Run: 03/31/2020 Time: 12:17
Windows Process ID: 11656
Processor Model: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
Compiler: Intel(R) FORTRAN Compiler Version 14.0.0 (Build: 20140422)
Intel(R) C/C++ Compiler Version 14.0.0 (Build: 20140422)
Intel(R) Math Kernel Library Version 11.1.3 Product Build 20140917
Total number of cores available : 8
Number of physical cores available : 4
Number of processes requested : 1
Number of threads per process requested : 2
Total number of cores requested : 2 (Shared Memory Parallel)
GPU Acceleration: Not Requested
Job Name: file
Working Directory: G:thesis solidansys26.3.20203.57_ProjectScratchScr20AA
Total CPU time for main thread : 926.9 seconds
Total CPU time summed for all threads : 1072.0 seconds
Elapsed time spent pre-processing model (/PREP7) : 28.8 seconds
Elapsed time spent solution - preprocessing : 42.8 seconds
