VivekKamble
Case 1- If solution type is Driven terminal.
there is an option to select a reference conductor while assigning a Lumped port. You have to select the reference conductor and click "ok" port will be assigned.
Case 2 - If solution type is Driven Modal
you will get an option here to define new integration line
Try changing solution type to Driven Modal if the current solution type is Driven Terminal.
Regards
