Venk2286
Thanks Sai,
I'm simulating as a static structural problem. Infact i have solved using a RBD for the same model, where I have applied angular rotation on the joint. With the same analogy shouldn't we apply angular rotation only on the part which is going to be rotated ( Rotor).
