Assuming that you are using ANSYS Mechanical, I don't think that you can add load in KGs, it has to be in Newtons. Further, Standard earth gravity will only be applied to the model and the parts having the mass. If you choose to ignore the forces due to self weights, you can ignore the standard earth gravity.
-Aniket
