Change the 3D geometry to a 2D model.
In SpaceClaim
  • make a plane and slice through the solid geometry you were given,
  • delete one side then you have a face in the YZ plane.
  • Select the face in the YZ plane and Ctrl-C and Ctrl-V.  Now you have a surface.
  • Delete the solid.
  • Import the Points
  • Use a sketch to divide the surface into faces so that each point becomes a vertex of a face.
  • Use the Rotate Tool to rotate that surface about the origin and the Y axis by 90 degrees. Now the geometry is in the XY plane.
In Workbench
  • Select Geometry cell and change Analysis Type to 2D. You can only do this on a new Static Structural model.
In Mechanical
  • Don't import the displacements as an imported load.
  • Create a Displacement Load on each vertex and enter the displacement value where Z=X now.
