April 1, 2020 at 1:20 am
Hi win,
Thanks for the response. Understood.
Are the following steps inline with a general batch solve, regardless of the details of the scheduler?
1- create the problem in MAPDL and save the corresponding .log and .db file. (let's say jobfile.log and jobfile.db)
2-copy the .log and .db files to the cluster.
3-set the correct settings for the number of cores and memory and etc. and load the needed ANSYS module (let's say ansys193)
4- this command solves the problem with let's say 32 cores (again, assuming the scheduler is comaptaible):
ansys193 -np32 -i jobfile.log -o jobfile.out
5-when the solution is done, copy the .rst file to local machine and postprocess.
Am I missing any necessary step?
thanks
