Keyur Kanade
does this error occur only for these files?
can you please check the version you are using.
please use latest 2020R1.
please create a test case from scratch.
open workbench.
open geometry - spaceclaim
create a pipe.
mesh it
move to fluent and solve.
please check if you can do this simple test.
if you can not do this test, then it is installation problem.
if you can do this test then it may be a file problem.
Please check version.
the files might have got corrupted.
Keyur
