franke
I am also getting drag results with much higher magnitude than would be expected, coefficient of around 1.7 and force around 25000N any suggestions for this? I have all reference values and everything set? If there is any further info you need please let me know.
The domain is rectangular with the upper and lower bounds sset as wall. Should the upper and lower walls be set as moving? it is a constant velocity through the flow
