What evidence do you have that a model with a Linear mesh will run as a Quadratic element?
Is it because you see an extra node in the mesh Statistics as shown below?
That doesn't imply the element runs as quadratic.  After this model solves, I can look in the Solution output and see that one linear element BEAM188 was used.
If I change to a Quadratic mesh...
then I get one Quadratic BEAM189 element in the Solution output.
You might ask, "Why is there an extra node?"  I expect it is used to orient the beam cross-section.
If this post answers your question, please click the Is Solution link below (when logged in) to mark this discussion Solved.
