Wenlong
Hi
Please post the error message in another thread. Maybe titled as "EREINF error message", so that it can be better viewed by others. But here is the command I use:
finish
/prep7
! Get the maximum element type id and section id
*get, typid, elem, 0, typm
*get, secid, secp, 0, num, max
sectypeid = secid + 1 ! Create a new section id by shifting the max by 1
etype_id = typid + 1 ! Create a new type id by shifting the max by 1
! Define the reinforcement section type and Mesh200 element type
secarea = 50 ! Define a section area for the reinforcement
sectype, sectypeid, reinf, discrete ! Define a discrete reinf section
secdata, steel_mat_id, secarea, mesh ! Define the section properties
et, etype_id, 200, 2 ! Define a new element type
! Generate Mesh200 elements
cmsel, s, rebars, elem ! Select the name selection "rebars".
! The name selection has to be bodies instead of edges
emodify, all, type, etype_id ! Change the element type to Mesh200
emodify, all, secnum, sectypeid ! Change the section to discrete reinf
! Generate Reinf264 elements based on Mesh200 and solid elements
cmsel, a, concrete, elem ! Add concrete to the selection
EREINF ! Generate reinforcement elements
esel,s,ename,,mesh200 ! Select the Mesh200 elements
edele,all ! Delete the Mesh200 elements
FINISH
allsel,all
/SOLU
OUTRES,ALL,all
Thanks,
Wenlong
