Once you have found the minimum Life, say that is 50,000 cycles, then after 1,000 cycles you have used 2% of the Life.  After you have accumulated 25,000 cycles, you have used 50% of the Life.
If you insert a Damage result, then you can enter the Exposure in seconds and it will do the division for you.
