Hi Wenlong,
Thank you again for your contribution. Deeply appreciated!
Unlike you I'm not able to solve the structure with the code I attached in the previus post. In particular:
1) When I try to solve using only Dy displacement, the program gives me result identical to yours (hence probably is not considering DT?)
2) When I add also DT for the link elements, program doesn't give me a solution, and the following error comes out on the Output Window:
*** ERROR *** CP = 2.578 TIME= 152:05
A large negative pivot value ( -1.110223025E-16 ) has been encountered
in the global assembled matrix at the UY degree of freedom of node 7.
This may be caused by a bad temperature-dependent material property
used in the model.
There are 2 small equation solver pivot terms (e.g., at the UY degree
of freedom of node . Please check for an insufficiently constrained
model.
Actually I'm using an APDL version older than yours (mine is 18.2). Do you think something has changed between the two version and that I should therefore update the program?
Best regards,
Matteo
